Question
How can I update Articles quicker?
  • September 6, 2022
  • 147 views
I need to link on the bottom of each article pages to related articles. At the moment i need to add the links manually which makes a lot of work if i need to add or change something
  • September 9, 2022
Hey @user1862​ Racheal from the support engineer team hereπŸ‘‹πŸΌ
While there is no out of the box way to bulk update Articles, you may be able to do this a bit quicker using our Articles API. Check out our dev docs, as well as this Article!
