How do I submit my sitemap for my Help Center to Google? | Community
  • February 3, 2021
  • 1432 views
Hi folks,
I want to submit the sitemap for my Articles to Google, where is this? I presume it exists?
Thanks,
Tom
Hi @user877​ , If you are looking for a Sitemap to download/upload to Google, afraid Intercom doesn't support that.
You can use online Sitemap builders for that, Like:
https://writemaps.com/
https://www.xml-sitemaps.com/
I hope this will be helpful 🦄
  • February 3, 2021
  • February 3, 2021
Ugh that's a pain. And it looks like no webhooks are sent whenever an article is updated/deleted/added, so we just have to run something every day to check.
  • February 3, 2021
Hey @user877​, just to add to Roy's response, you don't need a sitemap for our Help Center. It's designed in such a way that Google can crawl it without one. You can read more about this here.
  • February 3, 2021
Thanks @eric f11​ I'll have a look.
Is there are updated article about this? It’s going to a deadline.
