Is there an easy way to obtain a word count of all the articles in our Help Center? | Community
  • September 17, 2021
  • 185 views
We are planning to translate our ~700 help articles to another language and I would like to obtain a word count for what we have written so far to estimate the cost. Is there a way to do this? I suspect we have to use the API or some other script to extract and then use another authoring tool that does word counts?
Hello @julie c11​ 👋,
Q - Is there an easy way to obtain a word count of all the articles in our help centre?
A - In Intercom, there is no option to track the word count of all articles. I suggest using Intercom Article API for that, More information can be found here.
Please, keep in mind that for translating articles there is an amazing app for that called Lokalise:
https://www.intercom.com/app-store/?app_package_code=lokalise-for-articles/p>
Also please check the Intercom blog on the following case:
https://www.intercom.com/blog/not-investing-in-localization-is-costing-you-more-than-you-think//p>
I hope the information provided by me will be helpful, let me know if you have any additional questions.
Best,
  • September 19, 2021
Best,
