Multi-tenant Help Center | Community
  • March 6, 2024
  • 163 views
We have different clinical trials that have their own requirements and we'd like to be able to have each trial have its own user manual. Trial 1 might use modules A, B, and C, while Trial 2 uses module A, B, D, E, and F.
Right now we have a generic user manual, so all trials get the same manual. I see that Intercom allows up to 30 help centers - we’re expecting to have more than 100 trials (and thus help centers) shortly.
I cannot do this through Intercom's user attributes since the same user (say, a Doctor) could work on both Trial 1 and Trial 2 and would need to see different UM content based on which trial they are working on at the moment.
Any suggestions?
Best answer by bernice
Hi @Arvita Tripati πŸ‘‹
This Article from our Help Center goes into detail on how display Help Center content for a subset of customers that match the rules you define. Hope this helps! πŸš€
bernice
  • Expert User ✨
  • 230 replies
  • March 11, 2024
