We are currently using a different product to house our internal documentation, however, we’d ideally want to keep it all in one place. Our team uses both our internal documentation as well as our client-facing help articles to resolve problems. I’m curious of some best practices on how others are organizing this information within intercom. Any ideas are appreciated!
What is the best way to organize both internal and client-facing articles?
Hey
Our Knowledge Hub allows you to manage all your support content in one place, which would make it easy for you to access your knowledge effectively.
Here are some best practices for organising your content:
- Use Folders: Add internal articles to relevant folders in the Knowledge Hub to keep your knowledge organized and easily accessible. You can move articles between folders as needed .
- Create Collections: For client-facing articles, use collections in your Help Center. Collections help users find information quickly and can be organized into multi-level structures for better navigation .
- Integrate External Sources: If you have existing documentation in other platforms like Guru, Notion, or Confluence, consider integrating them into the Knowledge Hub for a more comprehensive approach .
For more detailed guidance, you can explore the following resources:
- Organize folders in the Knowledge Hub
- Create collections in your Help Center
- Best practices for organizing your collections
Join the Intercom Community 🎉
Login to the community
Log in with SSOor
