Best answer by Nick Y
View originalWhen can we expected to be able to edit images in the article editor?
Hello @olu​ ,
Â
Can you provide a bit more information on the following?
Â
Do you want to crop images during working with the article?
Yes, i want to be to edit image size and also be able to crop images, basically the normal functions you'd expect from an image editor
Â
Sounds like something for @Product Wishlist​Â
Join the Intercom Community 🎉
Login to the community
Log in with SSOor
