Is it possible to run two banners at the same time?
  • June 8, 2021
  • 314 views
Best answer by Brent
Hi @lisa f12​ You can set up two banners to run at the same time but only one will appear at a time on any one page. If you set up banners to be page specific and on different pages then they should run both for the pages you've set them up for.
If you are trying to do this on one page (or all pages) then the next banner will pop if you set up the dismiss button, and they dismiss the banner.
Hope that helps.
Brent
Brent
Super User ✨
  • Super User ✨
  • 257 replies
  • June 8, 2021
Hope that helps.
Brent
