How can I combine Kajabi with Zapier to tag contacts?
  • December 31, 2020
  • 8 replies
  • 91 views
Hey all!  I am using Kajabi to identify logged in / logged out users. That is about it.  However, i want to tag them as they come in and this needs to be done on Zapier but I cannot get it to work properly.  Can someone possibly help?
The issue has been resolved here. Anyone who uses Kajabi and wants to track logged-in visitors in Intercom should put the following code in the theme.liquid file:
<script>
var APP_ID = "WORKSPACE_ID"; // Replace this with your workspace ID
window.intercomSettings = {
app_id: APP_ID,
{% if current_site_user %},
name: "{{ current_site_user.name }}",
email: "{{ current_site_user.email }}"
{% endif %}
</script>
<script>(function(){var w=window;var ic=w.Intercom;if(typeof ic==="function"){ic('reattach_activator');ic('update',w.intercomSettings);}else{var d=document;var i=function(){i.c(arguments);};i.q=[];i.c=function(args){i.q.push(args);};w.Intercom=i;var l=function(){var s=d.createElement('script');s.type='text/javascript';s.async=true;s.src='https://widget.intercom.io/widget/#39; + APP_ID;var x=d.getElementsByTagName('script')[0];x.parentNode.insertBefore(s,x);};if(w.attachEvent){w.attachEvent('onload',l);}else{w.addEventListener('load',l,false);}}})();</script>
@geoffrey m11​ , Wishing you a very Happy new year 🎅🎄
  • December 31, 2020
Hi @geoffrey m11​ , I'm not familiar with Kajabi, it's a website builder? If I get correctly, once customer make the log-in the first time, you want to tag them? is it correct?
it is a web builder of sort. That is correct.
  • December 31, 2020
Gotcha, you want to tag users once they make their first log-in? In this case, you can use Series to reach this goal.
  • December 31, 2020
@geoffrey m11​ , You need to use Series for that. Here some example:
Series-First-LoginEntry Rule:
Series-First-Login1Let me know if you have any questions. Happy to help.
Sent you a fb message.
  • December 31, 2020
<script>
app_id: APP_ID,
{% endif %}
</script>
Roy, it has been a pleasure. Thank you so much for taking the time out to figure this out.
Hey @Roy
Wondering if this code is still a valid code? I now have access to the Theme.liquid file in my kajabi projects, but wondering where in the code i should put it. I can share an example of where i’ve tried. Not sure it’s working though.
