Issues triggering workflows in an SPA using GTM | Community
  • Mar 27, 2024 11:38 PM UTC
  • 282 views
I have intercom messenger installed in my SPA using GTM. In various places in the product I have buttons with the key value pair data-testid="get-help".
The issue I’m having is that when the site loads one button with the above data-testid is visible and clicking it triggers the messenger as required. See first image below, help button on the left triggers a workflow in the messenger (all fake data btw).
I then have the following, which shows when a user clicks a different button and in this space we have another help button (see top left of the green space). This button again has data-testid="get-help" and operates in the exact same way as the other help button but when clicking it, it doesn’t trigger the workflow in the messenger.
I don’t understand why it’s not triggering the workflow and how to resolve this. Any help/guidance appreciated.
Hi @Kieran Witt ! Ebenezer here from Engineering Support👋.
It looks like you already wrote into the Support Team and got an answer from my colleague Joel.
I’ll repost the answer here just in case;
If you’d like the Messenger to launch from a specific button, link or element in your app, site or mobile app you can create a custom launcher. For example, you can trigger the Messenger to open when a customer clicks on your ‘Talk to us’ button or chat icon.
This article will guide you through the process of creating a custom launcher so that it feels completely at home on your product, site or mobile app.
Note: You can add as many custom launchers to your product, website or mobile app as you wish!
  • Mar 28, 2024 9:22 AM UTC
Can’t edit for some reason so an improved post below…
In intercome I have a workflow set to trigger a messenger chat when buttons with the data-testid="get-help" are clicked.
But when I open a new button appears (with the data-testid) on the page without the URL changing it does not trigger the workflow.
Below is what shows when a user clicks a different button and in this space we have another help button (see top left of the green space). This button again has data-testid="get-help" and operates in the exact same way as the other help button but when clicking it, it doesn’t trigger the workflow in the messenger.
  • Mar 28, 2024 4:04 PM UTC
Now solved by using the custom launcher
