Error to build in android using react native | Community
  • Dec 12, 2024 12:52 PM UTC
  • 264 views
Execution failed for task ':app:mergeExtDexDevelopmentDebug'.
> Could not resolve all files for configuration ':app:developmentDebugRuntimeClasspath'.
   > Failed to transform intercom-sdk-base-15.11.3.aar (io.intercom.android:intercom-sdk-base:15.11.3) to match attributes {artifactType=android-dex, asm-transformed-variant=developmentDebug, dexing-enable-desugaring=true, dexing-enable-jacoco-instrumentation=false, dexing-is-debuggable=true, dexing-min-sdk=24, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
Dec 18, 2024 3:56 PM UTC
Hey there ​@David Rappa! Emily here from Support Engineering at Intercom 👋🏼
I suspect this issue is a dependency conflict. Could you try updating your dependencies?
Considering The error "Execution failed for task ':app:mergeExtDexDevelopmentDebug'" suggests there might be a problem with the dex files in your Android project, our product team suggests focusing on the Android libs first:
  • Gradle
  • AndroidX
  • Compose
  • Accompanist
Typical dependency conflicts include different versions of Google Services or Android Support libraries. In some cases, updating the dependencies that use those services or updating the repository might resolve the issue.
Let me know how it goes! 💪🏼
Emilygav
Forum|alt.badge.img+6
  • Dec 18, 2024 3:56 PM UTC
  • Gradle
  • AndroidX
  • Compose
  • Accompanist
