Conflict Between Crashlytics and Intercom Signal Handlers in iOS | Community
  • Mar 6, 2025 2:58 PM UTC
  • 969 views
Issue Description
We're experiencing signal handler conflicts between Firebase Crashlytics and Intercom SDK in our app. During app initialization, we see multiple warnings in the console:
[Crashlytics] The signal SIGABRT has a non-Crashlytics handler (IntercomSDK_sentrycrashcm_signal_getAPI). This will interfere with reporting.
[Crashlytics] The signal SIGBUS has a non-Crashlytics handler (IntercomSDK_sentrycrashcm_signal_getAPI). This will interfere with reporting.
[Crashlytics] The signal SIGFPE has a non-Crashlytics handler (IntercomSDK_sentrycrashcm_signal_getAPI). This will interfere with reporting.
[Crashlytics] The signal SIGILL has a non-Crashlytics handler (IntercomSDK_sentrycrashcm_signal_getAPI). This will interfere with reporting.
[Crashlytics] The signal SIGSEGV has a non-Crashlytics handler (IntercomSDK_sentrycrashcm_signal_getAPI). This will interfere with reporting.
[Crashlytics] The signal SIGSYS has a non-Crashlytics handler (IntercomSDK_sentrycrashcm_signal_getAPI). This will interfere with reporting.
[Crashlytics] The signal SIGTRAP has a non-Crashlytics handler (IntercomSDK_sentrycrashcm_signal_getAPI). This will interfere with reporting.
This conflict could lead to incomplete or missing crash reports in production.
Feature Request
We need to add configuration options to enable/disable crash reporting services based on the environment or user preferences. This would allow us to:
  1. Choose which crash reporting service to use as primary (Crashlytics or Intercom's Sentry)
  2. Disable specific crash handlers when running in development environments
  3. Comply with user preferences regarding analytics and crash reporting
Technical Notes
  • Both Crashlytics and Intercom's Sentry are installing signal handlers for the same signals (SIGABRT, SIGBUS, SIGFPE, SIGILL, SIGSEGV, SIGSYS, SIGTRAP)
  • The initialization order matters and can affect which handler takes precedence
  • Some SDKs provide configuration options to disable crash reporting (Intercom has enableCrashReporting option)
  • We may need to implement delayed initialization or other techniques to avoid conflicts
Priority
Medium - This issue doesn't crash the app but does impact our ability to receive complete crash reports from users, which affects our ability to fix actual crashes.
Hey ​@Eldhose Lomy Ebenezer here from Engineering Support👋.
Could you write into us with this issue, we’ll need to do some deep debugging to find out the issue is.
This will be easier via the Messenger.
  • Apr 22, 2025 8:55 PM UTC
Same for me, would like to know how this will ended up.
I don’t immediately see issues with the intercom iOS crash handler — but i’m here to ask for the same thing.
it is not safe to attach multiple crash handlers to an iOS app at once — signals are re-entrant and there’s no way for two unrelated engineering teams to implement them safely and concurrently
Since i’m already using another crash handler I”d like to turn it off for intercom.
​@Ebenezer.Laleye would you be able to confirm that the guidance found here is still up-to-date?
If i were to follow this would it disable any other class of intercom logs?
We are experiencing the same signal handler conflict. Firebase is not able to report crashes. Even worse, the app frozen when a crash occurs.
Have you guys introduced a feature to disable crash handling on Intercom? TIl then, we will need to remove it from our app.
Thanks
Hi All,
Just want to get back here and say that this bug has been fixed in later versions of the SDK. The latest version as of writing is 19.4.1.
