Microphone permission now required for Android? | Community
  • Apr 5, 2024 6:40 PM UTC
  • 6 replies
  • 1289 views
It looks like Intercom added microphone support recently (android.permission.RECORD_AUDIO) but it appears to be required not optional - this is reducing the number of devices we can install on - specifically some tablets that don’t have microphones.  It seems like this should be optional by default?
I think you need to add:
<uses-feature android:name="android.hardware.microphone" android:required="false" />
Hey there, JT!
I’m going to forward your question over to our Support team so they can chat with you and the product team about this more smoothly. They should reach out to you via the email address that you signed up with, so be on the lookout for their email in the next day or two!
  • Apr 9, 2024 6:11 AM UTC
Nothing about this permission is mentioned in the readme on the github, while other permissions are called out.
  • Apr 14, 2024 6:14 PM UTC
Hey there, JT!
  • Jun 12, 2024 8:57 PM UTC
Hey there, JT!
I wish I could dislike this response
  • Oct 15, 2024 4:02 PM UTC
Please add ability to disable this feature in Intercom UI.
Personally I think this feature is redundant since every Android keyboard have voice-to-text abilities, but if you introduced it, please allow users to disable it. Right now we are able to override permission in Manifest but microphone icon still exists in the Intercom dialog UI.
Thank you
@Jacob Cox could you please prfioritize this within the team? I believe there are no app publishers who loves their app’s PlayStore visibility being affected by such an insignificant (and keyboard builtin feature as mentioned above) feature. Thanks
I would also like this issue fixed.
