Connecting Intercom Survey Data with Domo
  • March 27, 2025
  • 12 views
Does anyone know a way to get Intercom survey data pushed to Domo on a daily basis (potentially using the json connector)?
Hey ​@Kiley 👋 Jacques here from Intercom Support. I hope all is well today!
Intercom doesn’t currently offer a public API for survey data, so there’s no direct way to push it to Domo via the JSON connector. That said, the best workaround is to export the survey results as a CSV from Intercom and then upload or sync that file to Domo on a daily basis using a script or a tool like Google Sheets + Domo connector.
Jacques Reynolds
