Can workflows in Intercom handle conditional branching?
Can workflows in Intercom handle conditional branching? I'm looking to create workflows that adapt based on user behavior or attributes. For example checkout, if a user clicks a specific link, they should receive one message, but if they don't, a follow-up should be sent instead. Does Intercom support this kind of dynamic flow? If yes, how can I set it up effectively? Any tips or best practices for conditional workflows would be appreciated!
Best answer by Milan
Hello ​@croftbarrow
Are you looking for those messages to be part of the same conversation (hence, you’ll need workflows, chatbot)?
Or, it can be different messages, independently sent (hence, you can either use Series or just independent messages)?
Either way, this can be done, and I’ll show you how to do it via workflows and branching. You should use Current page URL attribute. See this example:
I guess it is easy to understand but if not, feel free to ask.
This should be tested, of course, as I’m not entirely sure how fast Intercom attribute is updated. But you can also add some wait before the branching.
Hope that helps!
Hi,
I would suggest that you look into using  Intercom's Series feature
Milan
  • November 26, 2024
Hello ​@croftbarrow
Hope that helps!
Microsoft MAK keys Microsoft MAK (Multiple Activation Keys) are volume license keys that allow organizations to activate multiple copies of Microsoft software, such as Windows and Office, across many devices. Ideal for large-scale deployments, MAK keys simplify activation and management, ensuring compliance with licensing agreements. They provide a cost-effective and efficient solution for businesses, schools, and enterprises with numerous systems to manage.
