Custom Actions Result Mapping
Hi everyone.
In my workflow, I am using a custom action, which tests in the test step of the action builder without errors:
In the following result step of the action builder, I am (trying to) map the results as follows:
In my workflow, I am calling the action like so,
however, although the request goes through without errors
the answer fields {{business_name}} and {{address_city}} are not shown in the answer:
Clearly, I am doing something wrong mapping/linking/using the result, but I can’t figure out what.
Could somebody kindly assist?
Sunny greetings from Belgium! :)
Best answer by Racheal
Hey @jan-bernaise Racheal from the support engineer team here👋
Are you using the same user in your test call that you are in your test bot? I’ll go ahead and forward this conversation into support so we can take a better look for you!
  • June 16, 2023
I do. Awesome, thanks a lot! Looking forward to hearing back from them! :)
The thing is, that you were trying to map out an array to an object.
I am facing the same, have you found a solution yet?
