Bugs with Jira for Tickets using Workflows | Community
  • Oct 31, 2023 11:47 PM UTC
  • 619 views
I am trying to add some additional fields to the Jira tickets when they are created.
Bug #1:
The additional fields do not show up on the Jira side unless I specify “Bug” as the “Issue Type” field of the workflow. However when I do specify the “Bug” type I get 2 different Jira issues created. One Jira issue contains the additional fields and one does not.
Bug #2:
Also, as a side note I’ve re-installed the “Jira for Tickets” app a few times trying to get the above to work correctly and now I see multiple copies of the Jira actions in the workflow template.
Best answer by Eden
Hey @Josh Blackwell 👋 Eden from the support engineer team here.
This looks like it will need further investigation on our end, so I have escalated this with the Support team as a conversation. They will respond to you there as soon as possible!
Eden
  • Nov 9, 2023 10:03 PM UTC
  • Nov 10, 2023 4:27 PM UTC
Thank you
