Integrating Intercom with Circle.IO
We plan purchase Circle. IO for our course and community platform. We need to make sure that Intercom integrates with it before we finalize the purchase, though. Circle said it should integrate just fine, but we want to test it first. They asked me for an Intercom code snippet. Intercom bot directed me where I can find this. I shared it with Circle and they were unsuccessful with getting the snippet to work. Is there anyone at Intercom that can help me outside of the bot? Or anyone else use Circle and have had success integrating intercom?
Best answer by Joseph S.
Hi @Robin Laferney
I think best to involve your developers and have them reach out to intercom’s automation and integration team in messenger, as there is no ready-made app for such an integration. They may be able to provide some guidance on that.
Joseph S.
Super User ✨
  • Super User ✨
  • August 7, 2024
Hi @Robin Laferney
@Robin Laferney checking in to see how your Circle integration went, if you still need help with this feel free to reach out, I'd be interested to discuss your needs as I'm familiar with Circle and feel there should be  a few ways to integrate if you've had trouble getting it connected.
Miranda Babbitt
Another thought—you could use Zapier’s Circle.so integration? Intercom connects with Zapier, which means that you can connect to Intercom to Circle.so (and any of the other 7,000+ apps via Zapier).
I’m not sure if it has the specific functionality you’re looking for, but you can check out what it could do for you here
  • October 21, 2024
Hey Team, has anyone had any luck with this one?
I have been able to input the code snippet however unable to find the correct way to plug the user details into it (email, name etc).
@Robin Laferney ​@Tim Lea  I’ve managed to initialize intercom and set my user and company props successfully! That’s the snippet code within circle custom code area:
The trick is that we have some user data stored on window.circleUser browser object.
<script>
 // function to see if intercom is initialized or not
  function isIntercomInitialized() {
    return typeof Intercom === 'function' && Intercom('booted');
 // function to get email domain
  const getCompanyByEmailDomain = () => {
    return window.circleUser.email.split('@')[1]
 // function to init or refresh intercom instance
  async function initOrUpdateIntercom() {
    const companyDomain = getCompanyByEmailDomain();
    const hash = await generateHash();
    window.intercomSettings = {
      api_base: "https://api-iam.intercom.io",
      app_id: "intercom-app-id",
      email: window.circleUser?.email,
      user_id: window.circleUser?.email,
      user_hash: hash,
      company: {
    if (isIntercomInitialized()) {
      Intercom('update', window.intercomSettings);
    } else {
      Intercom('boot', window.intercomSettings);
  // function to generate hash HMAC-SHA-256
  async function generateHash() {
    const secretKey = 'intercom-secret-key';
    const userIdentifier = window.circleUser.email;
    const enc = new TextEncoder();
    const keyData = enc.encode(secretKey);
    const userData = enc.encode(userIdentifier);
    const cryptoKey = await crypto.subtle.importKey(
      'raw',
      keyData,
      { name: 'HMAC', hash: { name: 'SHA-256' } },
      false,
      ['sign']
    const signature = await crypto.subtle.sign('HMAC', cryptoKey, userData);
    const hashArray = Array.from(new Uint8Array(signature));
    const hashHex = hashArray.map(b => b.toString(16).padStart(2, '0')).join('');
    return hashHex;
 // init intercom
  initOrUpdateIntercom();
</script>
<!-- default intercom script -->
<script>
  (function() {
    const APP_ID = "intercom-app-id";
    } else {
      var w = window;
      var ic = w.Intercom;
      if (typeof ic === "function") {
        ic('reattach_activator');
        ic('update', w.intercomSettings);
      } else {
        var d = document;
        var i = function() { i.c(arguments); };
        i.q = [];
        i.c = function(args) { i.q.push(args); };
        w.Intercom = i;
        var l = function() {
          var s = d.createElement('script');
          s.type = 'text/javascript';
          s.async = true;
          s.src = 'https://widget.intercom.io/widget/' + APP_ID;
          var x = d.getElementsByTagName('script')[0];
          x.parentNode.insertBefore(s, x);
        if (document.readyState === 'complete') {
          l();
        } else if (w.attachEvent) {
          w.attachEvent('onload', l);
        } else {
          w.addEventListener('load', l, false);
</script>
