Question
What is the difference between token and acess_token returned while trading the authorization code
  • August 30, 2022
  • 21 views
  • September 1, 2022
Hey @svc-dev​ Racheal from the Support Engineer team here 👋
Taking a look at our OAuth docs here on trading your authorization code it looks like there should only be an access_token field returned:
ruby ssl_server.rb == Sinatra (v1.4.7) has taken the stage on 4567 for production with backup from Thin Thin web server (v1.6.4 codename Gob Bluth) Maximum connections set to 1024 Listening on 0.0.0.0:4567, CTRL+C to stop [05/May/2016:10:45:32 +0000] "GET / HTTP/1.1" 200 512 0.0041 CODE: XXXXXXXXXXXXXXXXXXXXX STATE:example ACCESS TOKEN: YYYYYYYYYYYYYYYYYYYYYYYYYY [05/May/2016:10:45:36 +0000] "GET /callback?code=XXXXXXXXXXXXXXXXXXXX&state=example HTTP/1.1" 302 - 0.7180 [05/May/2016:10:45:36 +0000] "GET /home HTTP/1.1" 200 12 0.0004
