Getting unsafe-eval CSP error!
Hi
I’m getting unsafe-eval CSP error from script-src policy.
Can this be fixed somehow without adding unsafe-eval to the policy?
Do you have any other script version without eval inside your JS code?
Attaching screenshots.
Regards
Shaq Payne
  • 41 replies
  • March 9, 2025
Hey Matt, Shaq here from the Support Engineering team😀
Intercom scripts may trigger Content-Security-Policy (CSP) warnings due to the use of the eval function, which is generally not recommended as it can increase the risk of XSS attacks. However, Intercom supports Google strict CSPv3, which includes directives that can help mitigate these risks without enabling unsafe-eval.
If you are using a strict CSP, you can include nonce-source(s) for scripts loaded by the Messenger, which allows you to maintain security without enabling unsafe-eval. Despite these warnings, the functionality of Intercom should not be affected if the CSP is configured correctly. This guide her has a little more context as well: https://www.intercom.com/help/en/articles/3894-using-intercom-with-content-security-policy
Let me know if I can clarify anything!
  • March 10, 2025
Hey Shaq, thanks for the answer.
Can you please give me an example of how to include nonce for script loaded by Messenger?
We’re already adding nonce to intercom script, what else can I do?
Also, what warnings here we’re talking about?
Thanks
Matt
  • March 10, 2025
@MattWD did you find a solution to this? I’m also confused about how we’re supposed to add the nonce value to scripts loading inside their SDK code. Trying to fit Intercom under our CSP policy has been a nightmare, to say the least.
  • March 19, 2025
@Jordan Ramey instead of adding a nonce to the intercom scripts you add the nonce attribute and value to any script tags in your html response (matching the nonce in the script-src directive of your CSP header) and set strict-dynamic as a source expression in script-src, which propagates the trust to any script loaded by a tag or script with the nonce attribute.
