Is there a way to create sub-bullets?
In Word when you create an ordered list you get...
  1. first bullet
  2. second bullet
    1. sub-bullet
It looks like even the forums have this functionality! Does this exists when writing an article in the help center? I can't seem to find it.
Best answer by Eric Fitz
Hey @brandon l​ πŸ‘‹ right now, it's not possible to create sub-bullets within an article. Our product team has article formatting in mind for the months ahead - might I suggest that you also bring this feature request to our Product Wishlist group?
  • August 27, 2020
  • September 11, 2022
Hi @brandon l & @Eric. To create an indented bullet point, simply use the - then tap the "space bar" --> This will auto-indent with a bullet point. It has helped my macros, I hope it helps yours too.
  • Example :)
