How to import company's
  • October 29, 2021
  • 588 views
Hi, I just exported a few companies but there seems no way to reimport the company's, it's only possible to import leads and users.
Is there a way to import the the same data?
sadly there are alot of features, that are not available for companies.
Best answer by Eric Fitz
Hey @jeffrey h​, company data cannot be imported via CSV import. I'm happy to flag this as a feature request for you via our @Product Wishlist​ group.
For now, you can update company data via our API, using this endpoint; https://developers.intercom.com/intercom-api-reference/reference#create-or-update-company/p>
  • 1630 replies
  • November 1, 2021
  • April 26, 2022
Hello! You can use Skyvia to import companies into Intercom: https://skyvia.com/data-integration/intercom-csv-file-import-and-export. Skyvia is a 100% cloud tool for automatic Intercom CSV import with powerful transformations.
  • 6 replies
  • September 9, 2022
Hi Eric, just wanted to let you know this is frustrating. I just had a bunch of data entry done for some company data, and now I have to involve a dev to get it imported into Intercom.
  • 6 replies
  • August 25, 2023
Hi - appreciate this is an older thread, but does anyone have advice on best way to update Contacts to a Company enmasse?
So far I’ve learnt:
  • You can’t do mass updates via the API, just one by one requests.
  • You cannot update Company data via the User Import.
So is there any actual way to easily manage Contacts enmasse so you can assign them to a Company.
The only real way seems to be going through each contact one by one either with the User Interface or by API Calls.
Thanks.
