LastSeen Property Seems to Not Be Updated | Community
  • July 7, 2021
  • 16 replies
  • 303 views
Hi, The Last Seen property does not show the correct time when listing the users. As we can see from the screenshot. There is a green circle which means the user is currently online:
last-seen-not-updated
If I open a user profile, the field last Seen says the correct thing: Just now :
last-seen-good
For the same user there is also a problem that he does not receive a Post message from Intercom, even if he was really logged on the page. I'm thinking if that could be the reason that his data are not properly updated by Intercom...
Could you please explain why the date is not updated?
Thank you.
Best answer by Sam
Really not sure what could cause this. It may be worth sending Intercom a message to see if they can look into this from their end.
  • July 7, 2021
Never seen this issue. I know that the Just now system can be a bit temperamental. However, I've never seen it show different values like that. Are you sure you're looking at the same user?
  • July 8, 2021
Yes, this is another screenshot, where we can see that on a single screen. Dates got synchronized few hours ago, but only for a while and now we still can observe that for a user that is currently active (and he really is, this is our employe), Last seen date is few hours back. Sometimes it happens that time gets refreshed after a minute, or something, but for this user synchronization is much less frequent. As a consequence, he can not receive the Post messages in time.last-seen-not-updated-2
  • July 8, 2021
Actually, there are few users like that, for which their login time is not correct and they do not receive Posts.
  • July 8, 2021
We are using version 1 of Intercom.
  • July 8, 2021
  • July 8, 2021
Hello @mykhaylo​ ,
Can you check developer console errors?
  • July 8, 2021
Hi @roy s11​  Do you mean the browser debug console (opened by F12)?
  • July 8, 2021
I do not see any errors in a browser debug console.
  • July 8, 2021
@user1030​ Can you please advise how to contact Intercom team?
  • July 8, 2021
You can contact them directly through their own Intercom Messenger - it appears in the bottom right. They might be a bit slower to reply now as they're out on vacation/holiday. Someone should be able to help you debug this and hopefully they can see a bit more technical information from their end about what could be causing this.
Really hope you get to the bottom of this!
  • July 8, 2021
Thanks @user1030​ , that is an obvious way of communicating Intercom team, but I did not think about it 😃
  • July 9, 2021
Hey @mykhaylo​
You can access the Console with Command-Option-J
You can also access it from the Browser Menu (upper right corner of the window) > More Tools > Developer Tools
  • July 9, 2021
Checked that, no errors are seen in Network console, all HTTP statuses are green (20x, 30x).
But in the Console tab there is an error message:
Deprecation warning: value provided is not in a recognized RFC2822 or ISO format. moment construction falls back to js Date(), which is not reliable across all browsers and versions. Non RFC2822/ISO date formats are discouraged. Please refer to http://momentjs.com/guides/#/warnings/js-date/for more info. Arguments: [0] _isAMomentObject: true, _isUTC: false, _useUTC: false, _l: undefined, _i: 53488-09-21T14:15:49.000Z, _f: undefined, _strict: undefined, _locale: [object Object] Error at Function.createFromInputFallback (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:25:76 at https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:140:121 at https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:140:172 at Et (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:141:169 at kt (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:142:202 at xt (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:142:284 at i (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:6:23 at Object.a [as compute] (https://static.intercomassets.com/ember/embercom-45dc740393aeb3399b5f1cf071e5436a.js.gz:16467:20 at pe.n [as fn] (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:1177:12 at https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3146:180 at e.track (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3736:5 at pe.compute (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3146:150 at pe.value (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3147:48 at zt.value (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3541:113 at Vt.value (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3549:195 at Object.create (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:1343:566 at Object.evaluate (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3411:204 at Object.evaluate (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3343:13 at Xt.evaluateSyscall (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3561:61 at Xt.evaluateInner (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3555:138 at Xt.evaluateOuter (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3555:59 at pi.next (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3633:26 at pi.execute (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3632:19 at ei.handleException (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3567:10 at ni.handleException (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3588:433 at Jt.throw (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3563:170 at ht.evaluate (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3399:90 at Jt.execute (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3563:14 at ri.rerender (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3589:32 at Fi.render (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:1459:19 at https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:1482:31 at e.inTransaction (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3183:5 at Gi._renderRoots (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:1481:34 at Gi._renderRootsTransaction (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:1486:10 at Gi._revalidate (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:1486:489 at invokeWithOnError (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3895:196 at p.flush (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3887:74 at m.flush (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3898:292 at z._end (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3949:9 at z.end (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3911:218 at z._run (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3951:70 at z.run (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:3920:13 at u (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:2792:23 at Object.success (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:7569:48 at l (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:617:118 at Object.fireWith [as resolveWith] (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:618:698 at T (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:901:443 at XMLHttpRequest.<anonymous> (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:912:206 at XMLHttpRequest.n (https://static.intercomassets.com/ember/vendor-d4c4724b5a7836d9e0f3ae9fa49ed3fa.js.gz:30570:52
  • July 9, 2021
@lisa b11​  I can see the same error message for a good user, which does not have the problem related to Last Seen. I'm not sure the error is relevant to the issue.
  • July 9, 2021
When I send an email from Intercom to that user, he can receive it, but he does not receive the Posts.
  • July 26, 2021
I want to thank to Intercom team for helping in understanding the issue.
For those who will have similar issue, in our case that was caused by the fact of having multiple Intercom users with same email. In our actual Intercom Messenger integration we use an email to match the logged in user with an Intercom user. In the occasion when Intercom finds more than one with same email address, it will not able to identify which one has logged. To fix the issue, we will change the integration javascript code to send a user_id instead of email, which will be used to match to the Intercom user.
Another detail to note is that there are 2 cases that determine Intercom behavior:
  • more than one user with same email address, and all users have user_id populated - Intercom will not be able to match the logged in user
  • more than one user with same email address, but one of them has user_id property that is not populated - in this case Intercom will use a user with null user_id to match to the logged in user
