Why do I have duplicate users?
Show first post
  • July 12, 2022
Hi Eric,
We are specifying both the user name and id so that we can differentiate but the script gets an HTTP 409 response if there is more than one Intercom account with that same email address (but different userids).
The script we are using from our website is as follows:
    window.intercomSettings = {
      app_id: 'l234ab5c'
       window.intercomSettings.email = 'my.email@gmail.com';
       window.intercomSettings.userid = '1633067';
Why does this not uniquely identify the single Intercom account?
Nicolas T13
  • September 13, 2022
@eric f11​ does this also work when eliminating duplicate leads? I have leads up to 4 times with the same email but different User IDs. I already fixed the issue generating the duplicates, but now I need to remove those duplicates.
The problem is that I can't seem to be able to match the userID column (only email) when importing the CSV, so not sure how I can select the leads to eliminate.
  • November 24, 2022
It is super annoying that Intercom still does not have this basic feature of merging duplicates after so many years, while useless features seem to proliferate.
Hi thanks for the CSV suggestion. I will try using this. Is there an easy way of re-assigning the tickets/conversation off the people who you have identified as needing to be archived? I have currently identified 200 user-user duplications so manually going through each one and re-assigning the tickets isn’t viable.
Hi @Shaunt, Ebenezer here from Engineering Support👋.
I am more than happy to submit this as a feature request for our engineers to look into.
Could you reach out to us with this suggestion via Messenger? It will be a bit easier to keep track of this request with the feature.
  • September 23, 2024
Any update on the ability to merge duplicate users?
Like Intercom we have evolved and improved over the years. So has our user ID and people with old app version keeps creating duplicate. I don’t want to loose historic data by just randomly archiving the old one.
Any viable solution scoped in the last 3 years?
+1
If this is not fixed I will go. I spent hours of my day yesterday trying to figure out how to merge duplicated users because an old dev accidentally started sending our long id instead of the short one.
My final plan was to archive all contacts and resync them by calling Segment’s identify for each user. But that didn’t work. In Segment I see I get the error “Contact was reported duplicated but could not be searched for, probably due to Intercom search cache not being updated”. Now I’m left with 0 contacts on Intercom and no way to unarchive the old ones.
Literally I can’t spend more time fixing this. I have features to get to. I told the marketing team to just create their campaign in one of the other email services and that’s it.
  • April 15, 2025
can this feature please be prioritized? Thank you!
