Customized CSAT
How can I customize the CSAT survey? I need it to have two stages: one to evaluate the analyst and another to evaluate the company/product.
What steps should I follow to achieve this in the automation?
Hey Bruno 👋 Jacques here from Support Engineering!
You can navigate to the Workflows setting and select the trigger ‘Teammate changes conversation state’ and then select ‘Closed’ as the option to setup your Workflow to only send the CSAT Survey when a Conversation is closed.
You can then send a message instructing the User to rate your Analyst, and then add the CSAT block. Then send another message asking the User to rate your Product/Company and then add another CSAT block.
It would look something like the image attached below!
Also note that you can configure the Workflow to wait for a User to answer the survey before advancing to the next point in the Workflow (see second attached image).
Jacques Reynolds
  • August 8, 2024
Just perfect, tanks a lot Jacques.
  • 6 replies
  • December 25, 2024
HI
"I'm interested in this workflow, but I have a question: How will this be reflected in the reports?"
Hey ​@User281 Ebenezer here from Engineering Support👋.
You should be able to see the reports of the CSATs if you create a custom report,
Let us know if this doesn't work for you.
  • 6 replies
  • March 3, 2025
Hey ​@Ebenezer.Laleye, can you say a bit more about the custom report answer? For example, how would we know which CSAT ratings apply for just the analyst, vs. the company/product, in reporting? Is there a way to differentiate or keep them separate?
I tried this and a change to 1 CSAT block updates all the other ones, too. How do I prevent that?
