How to add intercom on Wix.
  • October 11, 2024
  • 113 views
How do you install Intercom on Wix? I've tried adding the JavaScript to the custom code section on Wix, but it didn't work. I also downloaded the Intercom via certified code from the app market, but that didn't work either. Any advice would be greatly appreciated!
Hi @Ben Nawin, It’s Mat from the Support Engineering Team 😀
We are not officially support Intercom installation on Wix but there is an unofficial workaround that might work for you.
I hope it will help you install the Intercom on your website.
