I want to send an auto message to the user after he clicks on the “get help” button.
I didn't find a way to trigger a custom event like a button click.
thank you
thank you
Hey
Larissa here from Intercom Support. Thanks for reaching out!
First, you need to select the workflow with the trigger “Customer clicks a webiste element”.
Then, on the “Choose where to launch your workflow” section, you can select a button or a link on your website that people can click on to launch this bot, as per the screenshot below 👇
For more information about this workflow trigger, I’d suggest that you check this article.
I hope this helps!
