Android is crashing with compose 1.5.0 when pressing messsage send
  • August 31, 2023
  • 485 views
There was a ticket
which was closed without viable solution, so Iโ€™m creating new one.
Issue seems to be related to compose and accompanist versions.
Required accompanist version: 0.32.0
Required compose version: 1.5.0
Target and compile sdk: 34
Error looks like this:
java.lang.ClassCastException: androidx.compose.animation.AnimatedContentTransitionScopeImpl cannot be cast to androidx.compose.animation.AnimatedContentScope
        at io.intercom.android.sdk.m5.navigation.IntercomTransitionsKt$defaultEnterTransition$1.invoke(IntercomTransitions.kt:12)
        at androidx.navigation.compose.NavHostKt.createEnterTransition(NavHost.kt:346)
        at androidx.navigation.compose.NavHostKt.access$createEnterTransition(NavHost.kt:1)
        at androidx.navigation.compose.NavHostKt$NavHost$finalEnter$1$1.invoke(NavHost.kt:260)
        at androidx.navigation.compose.NavHostKt$NavHost$finalEnter$1$1.invoke(NavHost.kt:251)
        at androidx.navigation.compose.NavHostKt$NavHost$12.invoke(NavHost.kt:295)
        at androidx.navigation.compose.NavHostKt$NavHost$12.invoke(NavHost.kt:280)
        at androidx.compose.animation.AnimatedContentKt.AnimatedContent(AnimatedContent.kt:787)
        at androidx.navigation.compose.NavHostKt.NavHost(NavHost.kt:280)
        at androidx.navigation.compose.NavHostKt$NavHost$16.invoke(Unknown Source:27)
        at androidx.navigation.compose.NavHostKt$NavHost$16.invoke(Unknown Source:10)
        at androidx.compose.runtime.RecomposeScopeImpl.compose(RecomposeScopeImpl.kt:169)
        at androidx.compose.runtime.ComposerImpl.recomposeToGroupEnd(Composer.kt:2468)
        at androidx.compose.runtime.ComposerImpl.skipCurrentGroup(Composer.kt:2737)
        at androidx.compose.runtime.ComposerImpl.doCompose(Composer.kt:3352)
        at androidx.compose.runtime.ComposerImpl.recompose$runtime_release(Composer.kt:3303)
        at androidx.compose.runtime.CompositionImpl.recompose(Composition.kt:781)
        at androidx.compose.runtime.Recomposer.performRecompose(Recomposer.kt:1097)
        at androidx.compose.runtime.Recomposer.access$performRecompose(Recomposer.kt:124)
        at androidx.compose.runtime.Recomposer$runRecomposeAndApplyChanges$2$1.invoke(Recomposer.kt:569)
        at androidx.compose.runtime.Recomposer$runRecomposeAndApplyChanges$2$1.invoke(Recomposer.kt:537)
        at androidx.compose.ui.platform.AndroidUiFrameClock$withFrameNanos$2$callback$1.doFrame(AndroidUiFrameClock.android.kt:41)
        at androidx.compose.ui.platform.AndroidUiDispatcher.performFrameDispatch(AndroidUiDispatcher.android.kt:109)
        at androidx.compose.ui.platform.AndroidUiDispatcher.access$performFrameDispatch(AndroidUiDispatcher.android.kt:41)
        at androidx.compose.ui.platform.AndroidUiDispatcher$dispatchCallback$1.doFrame(AndroidUiDispatcher.android.kt:69)
        at android.view.Choreographer$CallbackRecord.run(Choreographer.java:1299)
        at android.view.Choreographer$CallbackRecord.run(Choreographer.java:1309)
        at android.view.Choreographer.doCallbacks(Choreographer.java:923)
        at android.view.Choreographer.doFrame(Choreographer.java:847)
        at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:1283)
        at android.os.Handler.handleCallback(Handler.java:942)
        at android.os.Looper.loopOnce(Looper.java:226)
        at android.os.Looper.loop(Looper.java:313)
        at android.app.ActivityThread.main(ActivityThread.java:8757)
        at java.lang.reflect.Method.invoke(Native Method)
        at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:571)
        at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1067)
We had to update compose version, and now we canโ€™t release our app because intercom crashes.
What is ETA on this fix?
Best answer by Eden
Hey @smart ๐Ÿ‘‹ Eden from the support engineer team here.
It looks like the team is aware of this issue and they are working on updating the Android SDK to prevent this from occurring. Iโ€™ll escalate this post as a conversation with the support team so that you can be added to the open issue and alerted when a fix has been pushed out for this! We will update in that thread as well. ๐Ÿ‘
Eden
  • 121 replies
  • September 1, 2023
