How to fix missing push notifications icon on Android?
  • January 7, 2022
  • 1730 views
We're using react native integration and when an agent messages a user, on iOS push notifications are displayed with the app icon, but on Android the icon is empty/missing. I tried a suggestion from the docs that says to put icons into assets folders, i.e. `/res/drawable-xxhdpi/intercom_push_icon.png`, didn't help
Best answer by Lisa B11
Hey @dmitry g​ 👋
I would recommend taking a look at this solution in StackOverflow to see if it helps 🙏
  • 250 replies
  • January 11, 2022
Hey @dmitry g​ 👋
