[react-native] removing event listener throws "Maximum call stack size exceeded" error
  • January 11, 2023
  • 8 replies
  • 1324 views
Howdy!
We're experiencing this issue after updating from 3.x SDK to 4.0.1 (https://github.com/intercom/intercom-react-native
react-native version: 0.70.5
Code sample (which is basically the same that you have in docs):
useEffect(() => { const subscription = Intercom.addEventListener( IntercomEvents.IntercomUnreadCountDidChange, (response) => { setCount(response.count); } );   return () => { try { subscription.remove(); } catch (e) { console.log(e); } }; }, []);
Calling subscription.remove on line 11 during effect cleanup triggers an exception.
Line 13 prints:
[RangeError: Maximum call stack size exceeded]
Without try/catch block the call just fails silently due to this - https://github.com/facebook/react-native/issues/32673(which doesn't contribute to the original problem, just makes it go unnoticed).
Let me know what other details you might need.
What can be done about it? Thanks.
Best answer by aykut.aydin
Hey everyone!
Just wanted to leave a reply here in case anyone is still experiencing this issue. The issue was resolved as the PR here was merged. If you use a version 5.0.0 or newer, you will not experience this issue any longer.
Diana Tripac
  • 157 replies
  • January 13, 2023
Looping in @user1207​  in case he has any ideas on that 🙌
Oseas
  • 103 replies
  • January 16, 2023
Hey @alex t​! Oséas here from the Customer Support Engineering team 🕵️
I've opened a bug report on our end for this issue so our Product Team can investigate this further. Could you please reach out to us via the Messenger so we can add the conversation to the report and, if necessary, request more info? Make sure to mention this thread when opening the conversation so my teammate who will get the convo knows which issue to link. Once we add it, any updates made will generate an internal notification in the convo and we'll be able to notify you.
Thank you very much for flagging this to us - really appreciate it!
  • January 17, 2023
Thank you, I will
  • February 28, 2023
We are experiencing the the exact same issue since updating to 4.0.1, we are using react-native. And it seems the crash only occurs when running android in debug mode and the component that has the subscription cleanup, dismounts. Not entirely sure yet if it's affecting the app in production. Ios seems to have no problems.
We are encountering the same issue: removing the subscription to the unread message count throws an error:
ERROR  Warning: Internal React error: Attempted to capture a commit phase error inside a detached tree. This indicates a bug in React. Likely causes include deleting the same fiber more than once, committing an already-finished tree, or an inconsistent return pointer.
Error message:
RangeError: Maximum call stack size exceeded.
For us it’s happening on iOS, both in the simulator and on device. RN 0.68, Intercom 4.0.1.
  • 6 replies
  • May 15, 2023
Any update on this issue? It’s marked as solved, but it doesn’t look solved!
  • May 23, 2023
I have yet to try it myself, but it does look like they have merged a pull request that fixes the infite loop issue in their latest release of react-native (5.0.0).
aykut.aydin
  • 104 replies
  • October 6, 2023
Hey everyone!
