Does the product tour work well on all browsers?
I had set live a product tour. On Safari, when I click next on the first card of my product tour, it doesn't take me to the next card and the page gets stuck. Is this behavior expected?
Best answer by Kevin Bendixen
@user860​ can't imagine that's expected behavior. Did you try the tour in a different browser to check if it's working probably there? Is the rest of Intercom working fine in Safari? Do you use some kind of blocker that could interfere?
Kevin Bendixen
  • 269 replies
  • January 29, 2021
  • 1630 replies
  • January 29, 2021
Hey @user860​, further to Kevin's comment, I'd recommend contacting our Support team directly through the Messenger if the rest of Intercom is working OK for you, and this is your only issue.
As per our System Requirements, you'll need to be running version 8.0 or higher of Safari.
