Product Tour pointers not rendering correctly even after Intercom HTML attribution
  • December 13, 2024
  • 76 views
I have successfully been able to integrate Product Tour for most of the platform. However,  have a section within my platform where a workflow needs to be completed by the users.
The workflow comprises of 4 steps and it’s a wizard style experience. all the 4 steps have the same URL and just the content on the page changes upon completing a step but the URL remains same.
Issue: The pointers which are meant to appear on the step 2 of the workflow appears on the Step 1 itself. The CSS elements are not visible on the Step 1 but still the pointers appear.
I have tried attributing the HTML with intercom <div> as well, the buttons are even highlighted in Pink within the tour editor after the attribution. It means the attribution worked, Despite this, the pointers appear on Step 1 instead of Step 2.
Best answer by madesigner
If the product tour pointers fail to render after Intercom HTML attribution on the SSO ID Rajasthan portal, follow these troubleshooting steps:
  1. Check for CSS conflicts: Ensure there are no conflicting styles in the portal's CSS that could interfere with the display of the product tour pointers.
  2. Verify JavaScript errors: Inspect the browser console for any JavaScript errors that might prevent the pointers from loading properly.
  3. Confirm correct HTML targeting: Ensure the HTML elements on the SSO ID Rajasthan portal are properly targeted by the Intercom integration.
  4. Test browser compatibility: Make sure the portal functions properly across different browsers and that the issue isn't browser-specific.
  5. Update Intercom integration: Ensure your Intercom integration is up to date to avoid compatibility issues.
  • December 14, 2024
If product tour pointers aren't rendering correctly after Intercom HTML attribution, try these fixes:
  1. Check for CSS Conflicts: Look for style conflicts that might affect pointer display.
  2. Inspect JavaScript Errors: Ensure there are no errors preventing the tour from rendering.
  3. Verify HTML Attribution: Double-check if the correct elements are targeted.
  4. Test Browser Compatibility: Check if the issue is specific to one browser.
  5. Update Intercom Integration: Ensure your Intercom integration and code are up to date.
These steps should help resolve the rendering issue.
  • December 16, 2024
