Different "starting points" based on user's plan?
We have users on different plans (silver, gold, platinum, vip, etc)... and we want to show different options for each.
Can't use URL rules as they are all using the same pages.
I'm passing a "plan" user attribute" through the Intercom code snippet, but I'm not sure how to use it to show different content/options on the bot (or different bots?) based on the value of that attribute.
Is it possible at all?
Best answer by Eric Fitz
You can control this in the audience settings for each bot - you can select the audience filter plan is or member_type is (or a combination of both!)
Hey @user1140​, do you pass these plans as the value of a custom attribute for your users?
  • March 10, 2022
Yes.
So my code looks something like:
app_id: "XXXX",
email: {EMAIL},
created_at: XXXX,
plan: premium,
member_type: premium
Got it, thanks! In that case, you'd need to create different bots, one for each possible value of the "plan" or "member_type" attributes.
  • March 10, 2022
Ok.
So I have two custom bots. How to I control which one is used for plan?
  • March 15, 2022
Thanks! <3
