Running code or an iFrame in the messenger?
  • June 20, 2021
  • 3947 views
Is it possible (or: what is the best way to...) run a small bit of code or show an iFrame in the messenger?
For a certain case in a custom bot, if a user chooses a certain path, I want to show the user a quick calculator.
The code is very simple - an HTML input, and about 5 lines of javascript. Is it possible to either put the code somewhere to show it in the bot? Or otherwise, can I use an iframe that shows a page where the calculator is hosted?
Thanks
Hi @user1140​ ,
You should build Canvas APP for that.
More Information can be found here.
Let me know if you have any questions about this, always happy to help.
  • Expert User
  • 1152 replies
  • June 21, 2021
Hi @user1140​ ,
