Resolution bot and Workflows
  • October 8, 2023
  • 353 views
Hi,
I sit possible to use “Let Fin answer” option in the Resolution bot?
Right now, for the custom answers I am writing, there is a path that I have defined.
I want to close the conversation once the customer has repsonded to “That helped”
In resolution bot, the path takes me to standard answers
In the Workflow with the trigger,  https://www.intercom.com/help/en/articles/4134615-customer-opens-a-new-conversation-in-the-messenger#h_c6b42fc0bb
how do make sure that the actions that I have defined in the Workflow flow inyto the Resolution bot
Best answer by Jennifer K
Hi @Radhika TK
Jennifer here from Customer Support
If you’re used to Intercom’s former automation settings, you may run into some new terminology in Fin's settings! Here’s what has changed:
  • Resolution Bot is now just called Fin, with the capability of both AI answers (powered by a mix of AI models and your Help Center content) and Custom Answers (written directly by you):
  • Any previous Resolution Bot answers you had written will now be found under Custom Answers.
  • Unanswered questions will appear under Custom Answers. You can also find your unanswered questions in the Fin report (Reports > Customer Support > Fin).
    Do you mean how to add Fin to a Workflow? You can add Let Fin answer as below 👇🏻
    I’ve also added a helpful article which explains how to use Fin alongside other automations: https://www.intercom.com/help/en/articles/7837520-using-fin-profiles-alongside-other-automations#h_347003ed56
    Let me know if this is what you’re looking for or you meant something else?
  • 984 replies
  • October 10, 2023
Hi @Radhika TK
